It is currently Sat Jun 07, 2025 6:11 am
 Post subject: Bevel / ribrest tutorial
PostPosted: Tue Feb 19, 2008 7:22 pm
First name: Ringo
I just completed an armrest bevel and rib rest and thought I would share my methods. Surely there are other ways to do this; this is what worked for me. Hopefully someone out there will find it useful. Also please note that I am not the best writer so please ask if anything is unclear.
I have been reluctant to do a bevel because I couldn't quite wrap my head around how to route the purfling channels on the sides without doing a bunch of hand work. Using .030" wide purfling this was not a task I looked forward to. Then one day it clicked that I could make a template that I could clamp to the sides to act as a guide for a router. I did a dry run on a mock-up body and decided it was good enough to attempt on a real guitar.
First off I made the side template, which is made of two pieces of mahogany bent in the side bender and then laminated together on a mold in a vacuum bag. The template actually sits atop the actual sides on the mold. I laminate my sides using vacuum as well; this makes everything nice and stiff and everything fits together quite well which is absolutely key. Here is the side template being glued up:
Next up I added an extra strip of lining to the sides where the bevel and ribrest would be. I just bent a couple extras when I bent the linings in the first place.
Once the top/back were attached, I dug right in and rough cut the bevel with chisels and a rasp, going a little deeper than the final bevel to make room for a veneer overlay which will match the bindings.
Once roughed out, I rubbed a piece of paper on the bevel to get a flat representation of the 3-D shape of the overlay (it helps to have dirty hands for this job):
Next I transferred the shape to my veneer and cut it with scissors. I put tape over the cut line for support to keep the veneer from splitting down the grain. Ask me how I know to do that... :oops:
Next I glued the overlay, taped it on, and cleaned it up:
Next I routed the binding and purfling channel for the rest of the guitar as if there was no bevel there. Sorry I didn't take a picture of that.
Next comes the heart of the system. I clamp on the templates as best as I can and route the purfling channels. I used a dremel with a 1/32" spiral bit, using the shank to register against the template. You have to keep the tool moving at a reasonable speed or you will burn the template. On the dry run I used a laminate trimmer with a guide which should also work if you're concerned about using the bit shank as a bearing. I was really wanting a Cochran plunge base for this operation!
For the middle of the ribrest, I cut as much as I could with the stewmac base:
and made a custom base to cut the convex portion:
After routing the channels the guitar should look like this:
The purfling is glued up just like normal; there is no interruption at the start/end of the bevel:
Once the bindings are glued in everything is cleaned up and it's finished:
Here's the finished guitar:
-Ringo
PostPosted: Tue Feb 19, 2008 8:04 pm
Last Name: Walden
City: Bartlesville
State: Oklahoma
Zip/Postal Code: 74006
I believe Lex Luthier is a genius! Too bad Superman! Ha! :D
Thank you for the great tutorial! [clap] [clap] [clap]
Steve Walden
Aspiring Builder,
Bartlesville, OK
PostPosted: Tue Feb 19, 2008 8:41 pm
Nice job Ringo, I appreciate your sharing that and it's definitely food for thought for me.
Thanks!
PostPosted: Tue Feb 19, 2008 9:04 pm
Thanks for the tutorial, I may have to try that someday.
PostPosted: Tue Feb 19, 2008 11:05 pm
Cool job. That looks really nice. Front and back. [clap] [clap] [clap]
PostPosted: Wed Feb 20, 2008 6:50 am
Thanks for that great tutorial Ringo. It is going directly into the archive.
PostPosted: Wed Feb 20, 2008 7:22 am
Absolutely LOVELY! Your description of the process is clear, thanks for the effort.
PostPosted: Wed Feb 20, 2008 9:26 am
Yes, Thanks much for your efforts Ringo!
It's Very clear and precise! [:Y:]
BTW- Beautiful guitar !!
PostPosted: Wed Feb 20, 2008 11:01 am
Very well done Ringo - thanks for sharing with us! [clap] [clap] [clap] [clap]
PostPosted: Wed Feb 20, 2008 12:10 pm
BTW, beautiful linings inside the guitar.
JOhn
PostPosted: Mon Apr 13, 2009 3:27 am
First name: Daniel
Last Name: Green
City: Milford
State: Ohio
Zip/Postal Code: 45150
Country: U.S of A
Thank you very much for sharing, I look forward to learning here at OLF
